i'm newbie... previous time i test inserting subs without any other changes with MultiAVCHD guide in other forum, i do it exactly like what he say, and i do it smoothly without problem, then make the iso and play it, then test new subs i just added, everything works fine...
now i test with other film, and when inserting BDMV folder there is some text log :
[05:25:15] *** Scanning playlist (00800.mpls). Please wait...
[05:25:15] *** Playlist EXT format: BDMV 1.1
[05:25:15] *** Detected main-path : [ID#000 Dur: 00:07:12.432] [00:10:00.000]
[05:25:17] *** Detected media file: [00890.m2ts, 00:07:12.425] (1375 MiB)
[05:25:17] *** Detected main-path : [ID#001 Dur: 00:00:53.678] [00:10:00.000]
[05:25:18] *** Detected media file: [00892.m2ts, 00:00:53.673] (157 MiB)
[05:25:18] *** Detected main-path : [ID#002 Dur: 00:19:38.218] [00:10:00.000]
[05:25:20] *** Detected media file: [00929.m2ts, 00:19:38.218] (3977 MiB)
[05:25:20] *** Detected main-path : [ID#003 Dur: 00:01:17.994] [00:10:00.000]
[05:25:22] *** Detected media file: [00895.m2ts, 00:01:17.983] (238 MiB)
[05:25:22] *** Detected main-path : [ID#004 Dur: 00:02:28.523] [00:10:00.000]
[05:25:23] *** Detected media file: [00933.m2ts, 00:02:28.521] (456 MiB)
[05:25:23] *** Detected main-path : [ID#005 Dur: 00:00:47.922] [00:10:00.000]
[05:25:25] *** Detected media file: [00932.m2ts, 00:00:47.914] (143 MiB)
[05:25:25] *** Detected main-path : [ID#006 Dur: 00:05:45.470] [00:10:00.000]
[05:25:26] *** Detected media file: [00935.m2ts, 00:05:45.461] (1076 MiB)
[05:25:26] *** Detected main-path : [ID#007 Dur: 00:01:08.401] [00:10:00.000]
[05:25:28] *** Detected media file: [00938.m2ts, 00:01:08.394] (203 MiB)
[05:25:28] *** Detected main-path : [ID#008 Dur: 00:02:30.775] [00:10:00.000]
[05:25:30] *** Detected media file: [00937.m2ts, 00:02:30.772] (473 MiB)
[05:25:30] *** Detected main-path : [ID#009 Dur: 00:02:45.373] [00:10:00.000]
[05:25:31] *** Detected media file: [00946.m2ts, 00:02:45.365] (521 MiB)
[05:25:31] *** Detected main-path : [ID#010 Dur: 00:18:05.584] [00:10:00.000]
[05:25:31] *** (more than 10 playitems: output suppressed)
[05:25:33] *** Detected media file: [00945.m2ts, 00:18:05.577] (3621 MiB)
[05:25:33] *** Detected main-path : [ID#011 Dur: 00:01:46.981] [00:10:00.000]
[05:25:35] *** Detected media file: [00941.m2ts, 00:01:46.975] (327 MiB)
[05:25:35] *** Detected main-path : [ID#012 Dur: 00:17:55.616] [00:10:00.000]
[05:25:36] *** Detected media file: [00940.m2ts, 00:17:55.615] (3523 MiB)
[05:25:36] *** Detected main-path : [ID#013 Dur: 00:00:58.099] [00:10:00.000]
[05:25:38] *** Detected media file: [00942.m2ts, 00:00:58.090] (176 MiB)
[05:25:38] *** Detected main-path : [ID#014 Dur: 00:15:41.065] [00:10:00.000]
[05:25:40] *** Detected media file: [00943.m2ts, 00:15:41.056] (2798 MiB)
[05:25:40] *** Detected chapters #: 00:00:00.000;00:04:43.908;00:09:42.748;00:12:41.84 4;00:16:53.178;00:19:25.789;00:21:45.345;00:26:11. 695;00:29:02.323;00:32:09.010;00:36:50.750;00:39:5 9.772;00:43:41.952;00:46:57.147;00:48:34.703;00:50 :12.467;00:53:46.514;00:57:07.257;01:00:04.350;01: 02:34.375;01:05:06.610;01:08:57.216;01:13:51.385;0 1:17:26.391;01:19:10.954;01:23:45.103;01:25:54.399 ;01:31:36.782;01:38:55.888
[05:25:40] *** Playlist duration : 01:38:56 (19072 MiB)
00801.mpls , 00850.mpls , 00851.mpls , 00888.mpls also like that... (more than 10 playitems: output suppressed)
then i check with BDinfo to find the biggest mpls and add the subs to that, it says biggest mpls :
playlist group length estimated bytes
00800.mpls 1 01:38:56 19.996.502.016
00850.mpls 1 01:38:56 19.996.502.016
00801.mpls 1 01:40:37 19.559.270.400
00851.mpls 1 01:40:37 19.559.270.400
i do it like before... because there is 2 different mpls with same size (biggest), i tried 00800.mpls, and when compile, i have error :
(RT) invalid numeric format (X)
(RT) access violation address 00AF35F4 in module 'calclib.dll'
then i test with 00850.mpls, and i got same error...
can anyone help me to solve this problem?
sorry... newbie here...
thanks before...
Results 1 to 1 of 1
multiAVCHD error
By cavusozkan in forum Authoring (Blu-ray)Replies: 7Last Post: 27th Nov 2011, 04:36 -
multiAVCHD shows only External subtitle after rendering the rest not show.
By JackyWang in forum Authoring (Blu-ray)Replies: 0Last Post: 23rd Aug 2011, 11:04 -
MultiAVCHD Subtitle Issues
By DeathToAnalog in forum SubtitleReplies: 0Last Post: 2nd Aug 2011, 02:41 -
multiAVCHD runtime error when trying to convert any video file
By i am x in forum Video ConversionReplies: 5Last Post: 25th Jun 2011, 22:53 -
AVI recomp error when adding subtitle
By Janey87 in forum SubtitleReplies: 1Last Post: 3rd Sep 2008, 03:47
